StarTech.com 15m White Molded Cat5e Patch Cable
£6.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 50-micron gold connectors ensure optimum conductivity while eliminating network signal loss due to oxidation or corrosion
  • Backed by StarTech.com lifetime warranty
  • RJ45 connector clip protectors help keep the plugs from snagging while routing the cable, for easier Cat5e cable runs
  • Length: 15m
  • Colour: White
  • Stock Status: In Stock
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT15MWH Cat5e Patch Cable (15 m) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Product Description StarTech.com Molded Cat 5e UTP Patch Cable - patch cable - 15 m - white
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Molded
Length 15 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m White...
£6.98
