Charge and Sync your Apple Lightning-equipped devices. The USBLT1MB 1m Black Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description | StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable - 1 meter (USBLT1MB) - Lightning cable - Lightning / USB - 1 m | Cable | Lightning cable - Lightning / USB | Technology | Double shielded | American Wire Gauge (AWG) | 24/28 | Length | 1 m | Colour | Black | Connector | Lightning - male | Connector (Second End) | USB - male | Features | Sync and charge | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ST7C51224, ST7C51224EU |
General | |
Cable Type | Lightning cable |
Interface Supported | Lightning / USB |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 1 m |
Plated Connector | Nickel |
Colour | Black |
Connectivity | |
Connector | Apple Lightning - male |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
