Charge or sync your Apple Lightning, USB Type-C, or Micro-USB mobile device using a single cable. This convenient USB multi-charger cable lets you charge and sync your Apple Lightning equipped devices, or your Android mobile devices, through a USB port on your laptop.
Offering a Lightning connector for your iPhone or iPad, a USB-C connector for your newer phone or tablet and a Micro-USB connector for your older mobile devices, it's the ideal cable for all of your mobile charging needs.
The 3-in-1 charging cable eliminates the need to carry multiple cables for all of your mobile devices.
You can also use the cable to charge your devices from a USB wall charger, car charger or power bank - great for people on the move, for providing simple, tidy connections.
With multiple connections available to you, this USB charging cable is perfect for leaving in your car or at your desk. Keep it connected to your car charger or plugged into your work computer so that when you commute to work or when you arrive in the office you know you're ready to go.
Product Description | StarTech.com USB Multi Charging Cable - 3.3 ft / 1m - Lightning / USB-C / Micro-USB - Braided - MFi Certified - USB 2.0 - 3 in 1 Charging (LTCUB1MGR) - USB cable - 1 m | Type | USB cable | Features | Braided | Length | 1 m | Connectors | 4 pin USB Type A - male | Connectors (Second End) | Apple Lightning - male , 24 pin USB-C - male , 5 pin Micro-USB Type B - male | Colour | Silver | Manufacturer Warranty | 2-year warranty |
General | |
Type | USB cable |
American Wire Gauge (AWG) | 22/28 |
Plated Connector | Nickel |
Length | 1 m |
Colour | Silver |
Weight | 120 g |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | 2-year warranty |
