StarTech.com N6PATC1MPL. Cable length: 1 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 42 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
Product Description | StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Purple, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MPL) - network cable - 1 m - purple | Type | Network cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Snagless, stranded, PoE ready | Length | 1 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Purple | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Network cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 1 m |
Weight | 42 g |
Colour | Purple |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, ETL, WEEE - up to 500 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
