The PEX2S553 PCI Express serial card lets you turn a PCI Express slot into 2 RS232 (DB9) serial ports. Based on a native single chip design (no bridge chip), this 2-port serial adapter card allows you to harness the full capability offered by PCI Express (PCIe), and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
The RS232 Serial adapter card (PEX2S553) is compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and MAC OS 10.4 and above. Plus, the serial card includes an optional half-height/low profile bracket that allows the card to be installed in any PCI Express slot, regardless of the size of the computer case. This product is a replacement for the PEX2S552 card.
Product Description | StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART (PEX2S553) - serial adapter - PCIe - RS-232 x 2 | Device Type | Serial adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express | Ports | RS-232 x 2 | Dimensions (WxDxH) | 12 cm x 10.5 cm x 2 cm | Weight | 61 g | Data Link Protocol | RS-232 | System Requirements | Microsoft DOS, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019 | Manufacturer Warranty | 2-year warranty | Designed For | P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16 |
General | |
Networking | |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 2 x RS-232 - 9 pin D-Sub (DB-9) |
Compatible Slots | 1 x PCI Express |
Miscellaneous | |
Compliant Standards | WHQL, FCC |
Software / System Requirements | |
OS Required | Microsoft DOS, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019 |
Dimensions & Weight | |
Width | 12 cm |
Depth | 10.5 cm |
Height | 2 cm |
Weight | 61 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 85 °C |
Humidity Range Operating | 5 - 85% |
Compatibility Information | |
