Add 2 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S22 2-Port PCI to USB 3.0 Card enables you to connect USB 3.0 peripherals to a PC through a legacy PCI host bus, which doubles the data transfer speeds when used with USB 3.0 peripherals than would be possible with a USB 2.0 host connection - up to 1.3 Gbps (PCI bus limit).
The card features an optional SATA power connection, which enables each port to supply up to 900mA of power to USB 3.0 bus-powered devices.
By supporting a legacy (PCI) host connection, the card adds updated peripheral connectivity, without having to upgrade to a PCIe-equipped motherboard or rely on the backward compatibility of USB 3.0 peripherals.
Product Description | StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power - Dual Port PCI USB 3 Controller Card (PCIUSB3S22) - USB adapter - PCI-X - USB 3.0 x 2 | Device Type | USB adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI-X | Bus Voltage | Universal (3.3 V & 5.0 V) | Ports | USB 3.0 x 2 | Dimensions (WxDxH) | 1 cm x 12.3 cm x 5.6 cm | Weight | 60 g | Data Link Protocol | USB, USB 2.0, USB 3.0 | Data Transfer Rate | 5 Gbps | Processor | NEC uPD720202 | Compliant Standards | USB 1.1, USB 2.0, USB 3.0 | Colour | Red | System Requirements | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits) | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: S3510BMU33, S3510SMU33, ST7300USB3B, UNI251BMU33 |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | USB, USB 2.0, SuperSpeed USB 3.0 |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 2 x USB 3.0 - 9 pin USB Type A |
Compatible Slots | 1 x PCI-X |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Compliant Standards | FCC, RoHS |
Colour | Red |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits) |
Dimensions & Weight | |
Width | 1 cm |
Depth | 12.3 cm |
Height | 5.6 cm |
Weight | 60 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 15 - 90% |
Compatibility Information | |
