StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller...
StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card
£26.25
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Storage controller
  • Controller Interface: eSATA-600
  • Interface: PCI Express
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
The PEXESAT32 2 Port PCI Express eSATA 6Gbps Controller Card offers simple connectivity between a host computer and eSATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the eSATA controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
Product Description StarTech.com 2 Port SATA 6 Gbps PCI Express eSATA Controller Card - Storage controller - 2 Channel - eSATA 6Gb/s - 6 Gbit/s - PCIe - PEXESAT32 - storage controller - eSATA 6Gb/s - PCIe
Device Type Storage controller - plug-in card
Bus Type PCIe
Interface eSATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Hard drive
Channel Qty 2
Max Storage Devices Qty 2
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Dimensions (WxDxH) 64.5 cm x 67.7 cm x 21.3 cm
Weight 67.9 g
Designed For P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, S251SMU33EP, S3520BU33ER, S355BU33ERM, TB31PCIEX16
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 2 Port SA...
£26.25
