Provide a high-speed, crystal-clear connection to your DVI digital devices. The DVIDSMM2M DVI-D Single Link cable features 2 male DVI (19-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 2m DVI-D male to male cable supports resolutions of up to 1920x1200 and transmission rates of up to 4.95 Gbits/sec, and is fully compliant with DVI DDWG standards.
Product Description | StarTech.com 2m DVID Single Link Cable M/M - DVI cable - 2 m | Type | DVI cable - single link | Technology | Double shielded | Features | Molded, thumbscrews | Length | 2 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - male | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Type | DVI cable |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 28 |
TMDS Links | Single link |
Plated Connector | Nickel |
Length | 2 m |
Colour | Black |
Connectivity | |
Connector | 18+1 pin digital DVI (Single-Link) - male |
Connector (Second End) | 18+1 pin digital DVI (Single-Link) - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
