Create Ultra HD connections between your High Speed HDMI-equipped devices. The HDMM2M High Speed HDMI cable (2m/6.5ft) features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray Disc players, HDTVs, DVD Players, stereo receivers, projectors and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
This is a replacement product for StarTech.com's 6 ft High Speed HDMI Cable - HDMI- M/M (HDMIMM6).
Product Description | StarTech.com 2m 4K High Speed HDMI Cable - Gold Plated - UHD 4K x 2K - Premium HDMI Video Cable for Your TV, Monitor or Display (HDMM2M) - HDMI cable - 2 m | Cable | HDMI cable | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 2 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Features | Moulded | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDPVGDVHDBP, DK30CH2DPPDU, DK30CHDPPDUE, DKWG30DPHPD, DKWG30DPHPDU, VHDCI24HD |
General | |
Cable Type | HDMI cable |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
