Power your USB Type-C devices. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Product Description | StarTech.com USB C to USB C Cable - 6 ft / 2m - 5A PD - M/M - White - USB 2.0 - USB-IF Certified - USB Type C Cable - USB C Charging Cable (USB2C5C2MW) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m | Type | USB-C cable | Technology | Double shielded | Features | Up to 100 Watts of power delivery | Length | 2 m | Connector | 24 pin USB-C - male | Connector (Second End) | 24 pin USB-C - male | Rated Current | 5 A | Compliant Standards | Thunderbolt 3 / USB 2.0 | Colour | White | Manufacturer Warranty | 2-year warranty |
General | |
Shielding Material | Aluminum mylar foil with braid |
Jacket Material | Thermoplastic elastomer (TPE) |
American Wire Gauge (AWG) | 24/26 |
Plated Connector | Nickel |
Length | 2 m |
Colour | White |
Weight | 90 g |
Connectivity | |
Miscellaneous | |
Compliant Standards | Thunderbolt 3 / USB 2.0, RoHS, USB-IF, WEEE |
Dimensions & Weight (Shipping) | |
Service & Support | 2-year warranty |
