Providing a stable platform for use with Compact Flash (I and II) and IBM Micro-drive media, this Compact Flash Card to IDE Adapter with 3.5" Bay Enclosure installs easily through a simple connection to an available IDE port, for use in either the front or back of a host computer.
Product Description | StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader (35BAYCF2IDE) - card reader - IDE | Product Type | Card reader - internal | Supported Memory Cards | CompactFlash Card type I, CompactFlash Card type II, Microdrive | Host Interface | IDE | Required Bay | 3.5" internal | Manufacturer Warranty | 2-year warranty |
General | |
Memory Card | |
Capacity | (max) |
Interfaces | |
Required Ports | 1 x 40 PIN IDC , 1 x 44 PIN IDC |
Miscellaneous | |
Included Accessories | 3.5-inch bay adapter, rear expansion slot bracket |
Compliant Standards | FCC, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
