Active HDMI to DisplayPort Cable HDMI 1.4 DisplayPort 1.2 USB Power 2 Year Warranty. This 3 m (10ft.) HDMI to DisplayPort cable with USB power lets you connect an HDMI video source, such as your laptop, desktop, Blu-ray player, or camera, to a DisplayPort monitor or projector without the need for additional video cables. The adapter cable features male connectors enabling you to connect your video source directly to the display, with no need for additional adapters or cables.
Convenient Connectivity
The active HDMI 1.4 to DisplayPort 1.2 converter cable offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. The adapter is powered via a USB port, avoiding the need for an extra power adapter.
Astonishing picture quality
With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The HDMI to DisplayPort Adapter cable delivers Ultra HD content to your DisplayPort monitor and supports 7.1 channel surround sound audio.
The HDMI to DisplayPort adapter is backward compatible with 1080p and 1440p displays, which makes it a great accessory to future-proof your existing setup for 4K video.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The HD2DPMM3M is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Product Description | StarTech.com 3m HDMI to DisplayPort Adapter Cable with USB Power - 4K 30Hz Active HDMI to DP 1.2 Converter (HD2DPMM3M) - video cable - DisplayPort / HDMI - 3 m | Cable | Video cable - DisplayPort / HDMI | Max Output Resolution | 3840 x 2160 - 30 Hz | Length | 3 m | Colour | Black | Connectors | HDMI - male , USB (power only) - male | Connectors (Second End) | DisplayPort - male | Compliant Standards | DisplayPort 1.2 | Features | 4K support, active cable | Manufacturer Warranty | 2-year warranty |
General | |
Cable Type | Video cable 4K support, active |
Interface Supported | DisplayPort / HDMI |
Jacket Material | Plastic |
Length | 3 m |
Features | USB powered |
Colour | Black |
Adapters & Converters | |
Max Output Resolution | 3840 x 2160 |
Refresh Rate | 30 Hz |
Connectivity | |
Connectors | 19 pin HDMI Type A - male , 4 pin USB Type A (power only) - male |
Connectors (Second End) | 20 pin DisplayPort - male |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC, RoHS, REACH |
Dimensions & Weight | |
Weight | 165.4 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.8 cm |
Shipping Depth | 20 cm |
Shipping Height | 2 cm |
Shipping Weight | 170.4 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
