StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter
£85.18
40 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • USB HUB WITH ETHERNET: 2x USB-A & 1x USB-C ports support USB 3.2 Gen 2 (10Gbps) transfer speeds with USB-A supporting BC 1.2 for fast device charging; Built-in GbE port LAN connectivity
  • HARD WIRED LAN: Desktop USB C Hub with built-in Gigabit Ethernet port (RJ45), Wake-on-LAN, V-LAN tagging & 9K jumbo frames for secure Ethernet connectivity, ideal for laptops/tablets without LAN ports
  • CHARGE & SYNC: 24W power supply adapter enables the USB-A port to provide 1.5A of power to data synced devices; The powered USB hub even charges devices when a host PC isn't connected w/ 2.4A of power
  • COMPATIBILITY: Supports Windows, macOS, Linux, iPadOS & Android w/ automatic driver installation in most versions, this USB hub adds ports to any USB-C/Thunderbolt 3 laptop, Ultrabook or smartphone
  • EASY & SECURE INSTALLATION: 3.3ft/1m USB Type-C cable included; Small, compact footprint; Securely mountable to a desk, wall or monitor with StarTech.com mounts (SSPMSUDWM/SSPMSVESA) sold separately
  • CONNECTIVITY TOOLS: Provided with this device, the application improves performance and security, featuring MAC Address Changer, USB Event Monitoring, Windows Layout & Wi-Fi Auto Switch utilities
  • Type: USB
  • Ports: 3
  • Data Transfer Rate: [N/A]
  • Managed: No
  • POE: No
Product codes
chevron icon
chevron icon
Expand the connectivity of your USB-C laptop with this new generation USB-C 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices and faster data transfer speeds. This self-powered 3-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one LAN port, one USB-C port, and two USB-A ports, so you can quickly connect more USB devices.
For faster and more consistent network connections, the USB 3.1 Gen 2 hub's integrated Gigabit Ethernet port provides wired network access that is fully compatible with IEEE 802.3/u/ab standards. The GbE port also supports Wake-on-LAN (WoL), so you can remotely wake your computer over your network.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. It features one always-on USB-A fast charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 3 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
chevron icon
Product Description StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter, 10Gbps USB Type C to 2x USB-A & 1x USB-C Ports, USB Hub w/ BC 1.2 Phone Fast Charging, Superspeed 10Gbps USB C Hub with GbE - Windows/macOS/Linux - hub - 3 ports
Device Type Hub - 3 ports
Subtype USB
Ports 1 x USB-C + 2 x USB 3.1 + 1 x 10/100/1000
Features Metal housing, UASP, USB Pass-Through, Fast Charging Port, DCP
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
Power AC 110/240 V 2 A
Dimensions (WxDxH) 10 cm x 6 cm x 2.5 cm
Weight 87 g
Colour Black, space grey
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Ubuntu 14/15/16/17, Microsoft Windows Server 2019, Linux LTS versions only, Android 8.0 (Oreo) or later, Linux Kernel 4.x or later, Google Chrome OS 61 or later, Ubuntu 18, Ubuntu 19, Apple MacOS X 10.10 - 10.15, Apple iPadOS 13.1 or later, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Localisation Japan, New Zealand, North America, United Kingdom, Europe
Designed For P/N: PEXUSB321C
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£85.18
