ITEM | QTY | PRICE |
StarTech.com 1 Port RS232 Serial to I...
4 | £593.12 |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
Product Description | StarTech.com 36in SATA Serial ATA Cable - SATA cable - Serial ATA 150 - SATA (F) to SATA (F) - 3 ft - red - SATA36 - SATA cable - 0.9 m | Type | SATA cable | Interface Speed | Serial ATA 150 | Length | 0.9 m | Connector | 7 pin Serial ATA - female | Connector (Second End) | 7 pin Serial ATA - female | Colour | Red | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: 10P6G-PCIE-SATA-CARD, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, CFAST2SAT25, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S25SLOTR, SAT2MSAT25, SATABAY5BK, SATBP125VP, SATSASBAY3BK, USB2SATAIDE, USB3SSATAIDE |
General | |
Storage Cable Type | SATA cable |
Length | 0.9 m |
Colour | Red |
Connectivity | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
