StarTech.com 3ft DP to DVI Converter Cable
£20.05
48 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Reduce clutter with a compact 3ft adapter cable
  • Avoid upgrades by keeping your DVI display
  • Avoid the hassle of converters that require additional cabling and power adapters with a plug-and-play cable adapter
  • Length: 91.4cm, <1m
Product codes
chevron icon
chevron icon
Eliminate clutter by connecting your PC directly to the monitor using this short adapter cable. This 3-foot DisplayPort to DVI-D adapter cable lets you connect your DisplayPort (DP) equipped Ultrabook, laptop or desktop computer to a DVI monitor or projector with no additional adapters or cables required. The passive adapter supports video resolutions up to 1920x1200 (WUXGA), perfect for high-resolution applications.
For the simplest and most discreet installation, this DP to DVI-D adapter connects directly from your DisplayPort video source to the DVI port on your display. It doesn't need a power source, unlike some converter dongles that require active power and separate bulky video cabling.
With this DP to DVI cable, you can bridge the gap between old and new technologies by converting your existing DVI display to work with your DP video source.
Upgrading every component in your A/V setup can be costly and time consuming. This cost-effective adapter lets you save the expense and hassle of buying a new display, by ensuring your existing DVI display will work with your DisplayPort equipment.
This 3 ft. adapter cable delivers a compact connection that eliminates excess to ensure a tidy, professional installation. For longer installations, StarTech.com also offers a DP2DVIMM6 6 ft DP to DVI cable (DP2DVIMM6), enabling you to choose the right cable length for your custom installation needs.
chevron icon
Product Description StarTech.com DisplayPort to DVI Converter Cable - DP to DVI Adapter - 3ft - 1920x1200 (DP2DVI2MM3) - display cable - 91.4 cm
Type Display cable
Length 91.4 cm
Connector DisplayPort - male
Connector (Second End) DVI-D - male
Compliant Standards FCC, RoHS, RCM
Colour Black
Designed For P/N: DK30CH2DEP, DK30CH2DEPUE
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£20.05
