Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT3MW 10ft/3m Lightning to USB Cable for iPhone, iPod and iPad enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
Product Description | StarTech.com 3m (10ft) Long White Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT3MW) - Lightning cable - Lightning / USB - 3 m | Cable | Lightning cable - Lightning / USB | American Wire Gauge (AWG) | 20/28 | Length | 3 m | Colour | White | Connector | Lightning - male | Connector (Second End) | USB - male | Features | Sync and charge | Manufacturer Warranty | 2-year warranty | Designed For | P/N: BOX4CABLE, BOX4HDECP, BOX4HDECP2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST1030USBM, ST73007UA, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB |
General | |
Cable Type | Lightning cable |
Interface Supported | Lightning / USB |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 3 m |
Plated Connector | Nickel |
Colour | White |
Connectivity | |
Connector | Apple Lightning - male |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
