Extend the connection between your DB9 serial devices by up to 3m. The MXT1003MBK Black Serial Extension Cable (3m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
Product Description | StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable (MXT1003MBK) - serial extension cable - DB-9 to DB-9 - 3 m | Type | Serial extension cable | Technology | Shielded | Length | 3 m | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 9 pin D-Sub (DB-9) - female | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: 1P3FPC-USB-SERIAL, IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232IS, ICUSB232PRO, ICUSB232V2 |
General | |
American Wire Gauge (AWG) | 28 |
Plated Connector | Nickel |
Length | 3 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
