Add three USB 3.0 ports (5Gbps) and a GbE port to your MacBook, using this silver, Apple style hub with an extended-length cable. Here's a must-have accessory for your MacBook. This portable USB 3.0 hub merges your USB peripheral and RJ45 network connections into a single, convenient combination hub. It gives you two vital connection types that are often missing from modern, port-limited laptops.
This silver, sandblasted USB hub matches the finish of your MacBook, and because it features a solid-aluminum casing that's both lightweight and rugged, it's perfect for travel usage. It also integrates a lengthier, 27 cm (10.5 in) cable, so you have the flexibility to place the hub, your devices, and your network connection, exactly where you need them.
This high-quality, Apple style USB hub features a Gigabit Ethernet port, giving you an easy way to expand your MacBook connectivity. And because the hub integrates a Gigabit Ethernet port, you can add wired network connectivity to your laptop in a location where Wi-Fi is unreliable or unavailable.
The hub's built-in USB cable has sufficient length to reach your laptop's USB 3.0 port, regardless of where the port is located.
Plus, the stylish hub features three USB 3.0 (also known as USB 3.1 Gen 1) ports in a compact housing. And, its silver, sandblasted finish provides a unique and trendy look when compared to traditional hubs.
The hub features a rugged yet lightweight housing, so there's no need to sacrifice dependability for portability. With its compact, USB-powered design and a built-in USB cable, you can tuck the combination hub neatly into your travel bag, and avoid the nuisance of carrying multiple separate adapters.
This USB 3.0 hub is perfect for travel, such as back-and-forth trips from home to office. Plus, the compact hub takes up minimal space on a desk, so you can use it in hot-desk or BYOD (Bring Your Own Device) environments.
This bus-powered USB hub installs quickly and easily, and it's natively supported in Windows 10 and 8.1, as well as Mac OS 10.11 and 10.10, with no additional drivers or software required. You can also avoid the nuisance and cost of purchasing new devices by using the USB 3.0 hub plus GbE with your current USB 2.0 and 1.x devices.
Product Description | StarTech.com 3-Port USB 3.0 Hub with Gigabit Ethernet - Up to 5Gbps - Portable USB Port Expander with Built-in Cable (ST3300G3UA) - hub - 3 ports | Device Type | Hub - 3 ports | Subtype | USB | Ports | 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000 | Jumbo Frame Support | Yes | Features | Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az | Dimensions (WxDxH) | 11.1 cm x 3.5 cm x 2 cm | Weight | 40 g | Colour | White, silver | System Requirements | Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0 | Manufacturer Warranty | 2-year warranty |
General | |
Subtype | USB |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 3 x USB 3.0 Type A , 1 x Gigabit LAN RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB power cable |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0 |
Dimensions & Weight | |
Width | 11.1 cm |
Depth | 3.5 cm |
Height | 2 cm |
Weight | 40 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -10 °C |
Max Storage Temperature | 70 °C |
