StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock
£493.47
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • DUPLICATE, ERASE AND DOCK: This 4-bay external cloner and drive eraser/ wiper performs standalone cloning or erasing of 2.5/3.5" SATA drives; Hard disk docking station for quick access to your 2.5/3.5" SATA drives over USB or eSATA
  • DRIVE COMPATIBILITY: Works with 2.5/3.5" SATA and IDE SSDs/HDDs of any capacity; Included IDE cable adapters support 40-pin/3.5in and 44-pin/2.5in drives; OS Independent; Hardware includes eSATA and USB-A cables and Universal Power Adapter
  • DUPLICATION AND ERASE MODES: Up to 4.2 GB/min Standalone sector-by-sector cloning; Target disk must be equal/larger than the source disk; Supports Quick Erase & Secure Erase (NIST SP 800-88 Rev 1 Purge); Disk mount / File transfer / Backup / Recovery tool
  • LCD MENU DISPLAY: Use push button menu navigation to select duplication and erase modes, and check drive info; USB 3.2 Gen 1 (5 Gbps) or eSATA (3 Gbps) Host Device Connection (optional); Top-Loading w/ Drive Doors & Eject Buttons; Multi-function LEDs
  • THE IT PRO'S CHOICE: Designed and built for IT Professionals, this hard drive copier and wiper tool is backed for 2 years, including free lifetime 24/5 multilingual technical assistance
  • Type: Hard drive Duplicator
  • HD Size: 2.5 / 3.5 shared
  • Power Supply: Power adapter
Product codes
chevron icon
chevron icon
Duplicate one SATA Hard Drive onto three Hard Drives simultaneously.
The SATDOCK4U3RE USB 3.0 and eSATA 1-to-3 Hard Drive Duplicator docking station enables you to duplicate/clone a single SATA hard drive to up to three other SATA drives simultaneously, as a standalone device. The duplicator can also function as a regular 4-bay hard drive docking station, by connecting to a host computer system. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) can be used to greatly enhance your computer's storage/backup capabilities.
Able to perform 1:3 sector duplication, including HPA, from a single SATA drive onto three others simultaneously (at a rate of up to 72 MBps), the duplicator/docking station can save you time and effort. As an external HDD dock, it can be connected to your host computer through USB 3.0 or eSATA, providing data transfer speeds up to 5 Gbps or 3Gbps respectively, from the hard drives to your computer system.
Features Quick and Secure Erase functions and support for IDE hard drives using the included SATA to IDE hard drive adapter (SAT2IDEADP).
chevron icon
Product Description StarTech.com 4 Bay USB 3.0/ eSATA Hard Drive Duplicator Dock for 2.5" & 3.5" SATA/ IDE SSD HDD - Standalone 1:3 Copier Docking Station (SATDOCK4U3RE) - hard drive duplicator
Device Type Hard drive duplicator
Colour Black
Installed Devices / Modules Qty 0 (installed) / 4 (max)
Supported Drives SATA-300
Storage Controller SATA (SATA 3Gb/s)
Hard Drive No HDD
OS Required Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
Power AC 120/230 V - 50/60 Hz
Dimensions (WxDxH) 29 cm x 17 cm x 8.3 cm
Weight 1.11 kg
Manufacturer Warranty 1-year warranty
Designed For P/N: SVA12DN4NEUA
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£493.47
