ITEM | QTY | PRICE |
WD 16TB My Cloud EX2 Ultra NAS
4 | £2,604.84 |
WD Black 2TB Performance Desktop Hard...
1 | £128.61 |
BT Converse 2100 Black corded phone
4 | £131.92 |
Connect four USB 2.0 devices away from your computer over Cat5 (40m) or Cat6 (50m). This 4-port USB 2.0 extender is an easy and inexpensive solution for creating workspace freedom. Now you can extend the distance of your USB 2.0 devices over a single Ethernet cable, up to 130ft (40m) over Cat5, or 165ft (50m) over Cat6.
Overcome the 16ft USB cable length limitation to create a more flexible and efficient workspace. Now you can place up to four USB devices in remote locations away from the host computer system. Position your hard drive enclosure, printer, scanner, webcam and other popular peripherals right where you need them, to save time and enhance your productivity.
Gain quick access to the USB devices you use most frequently. Often on the go? Use the two top ports for fast, easy connections to portable devices like flash drives, smartphones and tablets. Plus, you still have two front-facing ports for printers or other devices requiring a more permanent set-up.
The versatile USB2004EXTV supports Windows, Mac and Linux systems. Set-up is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
Product Description | StarTech.com 4-Port USB 2.0 Extender - 165ft (50m) USB Over Cat5/Cat6 Extender - Compact USB 2.0 Over Ethernet Extender (USB2004EXTV) - USB extender - USB 2.0 | Device Type | USB extender | Ports Qty | 4 | Form Factor | External | Data Transfer Rate | 480 Mbps | Data Link Protocol | USB 2.0 | Transmission Medium | CAT 5/6 | Max Transfer Distance | 50 m | Power | AC 120/230 V | Dimensions (WxDxH) | 5.2 cm x 8 cm x 2.2 cm | Weight | 325 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA5N3NEUA |
General | |
Colour | Black |
Networking | |
Ports Qty | 4 |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - mini-USB Type B , 4 x USB 2.0 - Type A |
Miscellaneous | |
Cables Included | 1 x USB cable , 1 x network cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 10 Watt |
Dimensions & Weight | |
Width | 5.2 cm |
Depth | 8 cm |
Height | 2.2 cm |
Weight | 325 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 80% |
Compatibility Information | |
