Add 4 USB 3.0 hub ports, plus 3 dedicated USB charging ports (7 total) through a single USB 3.0 host connection. The ST4300U3C3 USB 3.0 Hub enables simultaneous data hub and USB charging functionality by adding three dedicated USB charge ports, as well as four USB 3.0 data ports, for a total of seven ports, all through a single USB 3.0 host connection.
The USB hub ports are compliant with the SuperSpeed USB 3.0 specification, offering data transfer rates up to 5 Gbps, and are backward compatible with USB 2.0 and 1.x specifications.
This AC powered USB hub also integrates 3 dedicated USB charging ports, providing 2 x 1A and 1 x 2A ports, enabling both data hub and USB charging station functionality. Support for USB Battery Charging Specification 1.2 lets you charge most mobile devices, including the Apple iPhone, iPad, Microsoft Surface, Samsung Galaxy Tab and more.
Designed for easy access to the ports when connecting or disconnecting devices, the hub features an upright port orientation, in a compact and durable metal enclosure. For added flexibility, the hub includes a bracket for wall-mounted installations.
Product Description | StarTech.com 7 Port USB 3.0 Charging Hub - 4 x USB-A, 3 x USB-A Dedicated Charging Ports - Powered Mountable USB Charging Station (ST4300U3C3) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x SuperSpeed USB 3.0 | Features | Wall mountable | Compliant Standards | USB 1.1, USB 2.0, USB 3.0 | Dimensions (WxDxH) | 4.5 cm x 11 cm x 2.4 cm | Weight | 135 g | Colour | Black | System Requirements | Linux Kernel 2.4 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits) | Manufacturer Warranty | 2-year warranty | Designed For | P/N: PEXUSB3S3GE, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.0 Type A , 3 x USB 2.0 output Type A |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Colour | Black |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Linux Kernel 2.4 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits) |
Dimensions & Weight | |
Width | 4.5 cm |
Depth | 11 cm |
Height | 2.4 cm |
Weight | 135 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 50 °C |
Compatibility Information | |
