ITEM | QTY | PRICE |
StarTech.com 1 Port RS232 Serial to I...
4 | £593.12 |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
Turn a USB Type-C port on your laptop into three USB Type-A ports (5Gbps) and one USB Type-C port. This 4-port USB 3.0 hub lets you connect a wider range of peripherals to your MacBook Pro, MacBook and other USB-C laptops. The hub expands your laptop or desktop connectivity by enabling you to connect both USB-A and USB-C devices through a single USB Type-C or Thunderbolt 3 port.
Extend the life of your current USB 3.0 devices and take advantage of newer devices that feature USB-C.
This USB-C hub lets you expand your USB connection options using the USB-C port on your computer. It offers three USB-A ports and one USB-C port, so you can connect traditional USB devices as well as newer USB-C devices to your USB-C laptop.
You can travel lighter, with a single USB-C adapter that lets you connect virtually any USB peripheral.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. The hub is ideal for use in hot-desk or BYOD (Bring Your Own Device) environments.
For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C expansion hub is multi-platform compatible, which means it will work with a wide range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Product Description | StarTech.com 4 Port USB C Hub with 1x USB-C & 3x USB-A Ports (SuperSpeed 5Gbps), USB Bus Powered, Compact Portable/Laptop USB 3.0 Adapter Hub, USB 3.1 Gen 1/USB 3.2 Gen 1 Type-C Hub, White - Windows/macOS/Linux (HB30C3A1CFBW) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 3 x SuperSpeed USB 3.0 + 1 x USB 3.1 | Features | USB powered | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.1 | Dimensions (WxDxH) | 4 cm x 7.5 cm x 1.3 cm | Weight | 33 g | Colour | White | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X Genesys Logic GL3523 |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 3 x USB 3.0 Type A , 1 x USB 3.0 Type C |
Miscellaneous | |
Colour | White |
Cables Included | 1 x USB-C cable - 11.4 cm |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE |
Dimensions & Weight | |
Width | 4 cm |
Depth | 7.5 cm |
Height | 1.3 cm |
Weight | 33 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 60 °C |
