Provides a high-speed, crystal-clear connection to your DVI digital devices, with a long 40-foot cable. The DVIDDMM40 40ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and offers 40 feet in cable length, making it perfect for longer connections between your desktop or laptop computer and a DVI-D monitor or projector.
The 40 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
Product Description | StarTech.com Dual Link DVI Cable - 40 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM40) - DVI cable - 12.2 m | Type | DVI cable - dual link | Length | 12.2 m | Connector | DVI-D - male | Connector (Second End) | DVI-D - male | Compliant Standards | RoHS | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDP2DVIDP, DP2DVID2 |
General | |
Type | DVI cable |
TMDS Links | Dual link |
Plated Connector | Nickel |
Length | 12.2 m |
Colour | Black |
Connectivity | |
Connector | 24+1 pin digital DVI - male |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
