StarTech.com 6' DP to VGA Cable with Audio
£12.27
Delivery:
Standard: 1-3 working days
Key features
  • Create a clutter-free work environment by placing your audio and video cables neatly behind your monitor
  • Substitute a damaged or blocked audio port by connecting your speakers to your computer directly through the adapter
  • Provide crystal-clear picture quality with support for high-definition video resolutions up to 1920x1200 or 1080p
  • Length: 2m, 1m - <5m
Product codes
chevron icon
chevron icon
Connect the audio and video from your DisplayPort PC directly to a monitor. Now you can organize your workspace with less mess than ever before.
This unique 6-foot DisplayPort to VGA adapter cable features a built-in audio port, which enables you to connect a VGA monitor as well as speakers to your DisplayPort (DP) equipped desktop computer.
Remove the cable clutter from your desk. With the built-in audio port you no longer need to run a separate audio cable from your monitor or speakers directly to your desktop or laptop computer. Simply plug the audio cable from your speakers into the adapter cable for a simple and tidy solution.
In order to use the audio function of the adapter, it needs to be powered through USB. Simply connect a Micro-USB cable into the adapter from your computer, monitor or USB grommet in order to provide the necessary power.
The adapter guarantees you always have all of the connections you need. If the audio port on your computer is damaged or blocked, this adapter cable ensures you still have sound available for watching video presentations, listening to music while you work or chatting with your colleagues over Skype.
chevron icon
Product Description StarTech.com 6 ft / 2m DisplayPort to VGA Adapter Cable with Audio - DisplayPort adapter - 2 m
Type DisplayPort adapter
Length 2 m
Connectors DisplayPort - male
Connectors (Second End) 15 pin D-Sub (DB-15) - male , Mini-phone stereo 3.5 mm - female , Micro-USB Type B (power only) - female
Compliant Standards FCC, RoHS
Colour Black
Designed For P/N: DK30CH2DEP, DK30CH2DEPUE
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£12.27
