Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
StarTech.com 6 ft Cat5e Purple Molded RJ45 UTP Cat 5e Patch Cable
Key features
  • Molded RJ45 connectors
  • Carefully constructed and tested, to keep Near End Crosstalk (NEXT) well within acceptable limits
  • Colored hoods for departmental color coding
  • Constructed with top quality components
  • High quality 24 AWG copper wire
Product codes
chevron icon
chevron icon
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT6PL Cat5e Patch Cable (6 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable purple PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
chevron icon
Product Description StarTech.com 6 ft Cat5e Patch Cable with Molded RJ45 Connectors - Purple - Cat5e Ethernet Patch Cable - 6ft UTP Cat 5e Patch Cord (M45PATCH6PL) - patch cable - 1.8 m - purple
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568A
Wires per Cable 8 wires
Features Molded
Length 1.8 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Purple
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
