This 6ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
Product Description | StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M - 6ft HD15 to HD15 Cable (MXT101MMHQ) - VGA cable - 1.8 m | Type | VGA cable | Technology | Triple shielded twisted pair coaxial | Features | Molded, ferrite bead | Length | 1.8 m | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: BNDDKTCHVPRS, BOX4HDECP2, CDP2DPVGA, CDP2HDVGA, CDP2MDPVGA, CDP2VGAFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CVAGPD, DP2VGA3X5, KITBXAVHDPNA, MOD4AVHD, MOD4AVHDBT, RKCOND17HD, ST121HDBTSC, USB32HDVGA, USBC2VGCAPRO, VID2VGATV3 |
General | |
Type | VGA cable |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 28 |
Plated Connector | Nickel |
Length | 1.8 m |
Colour | Black |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - male |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | P/N: AGPVID5500A, BNDDKTCHVPRS, BOX4CABLE, BOX4HDECP, BOX4HDECP2, CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, CDP2DPVGA, CDP2HDVGA, CDP2MDPVGA, CDP2VGA, CDP2VGAFC, CDP2VGASA, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDBP, CDPVGDVHDMDP, CPNT2VGAA, DK30BACDD, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2, DKT30CHVW, DKT30CVAGPD, DP2HDVGA, DP2VGA, DP2VGA2, DP2VGA3, DP2VGA3X5, DP2VGAA, DP2VGAAMM2M, DP2VGAAMM3M, DP2VGDVHD, DS128, DS154, DSRXL, DVI2VGA, DVI2VGACON, DVI2VGAE, DVI92030202L, DVISPL1VV, DVIVGAMF, DVIVGAMFBK, HD2DPVGADVI, HD2VGAA2, HD2VGAE2, HD2VGAMICRA, HD2VGAMICRO, HDMI2VGA, HDVGADP2HD, IPUSB2VGA2, KITBXAVHDPNA, MCHD2VGA, MCHD2VGAE2, MDP2HDVGA, MDP2HDVGAW, MDP2VGA, MDP2VGA2, MDP2VGAW, MDP2VGDVHD, MDP2VGDVHDW, MDPVGDVHD4K, MNHD2VGAE2, MOD4AVHD, MOD4AVHDBT, MSTP3MDPUGBK, MSTS3MDPUGBK, PEXHDCAP2, PEXHDCAP60L2, RACKCONS1908, RACKCONS1916, RKCOND17HD, SLMPT2VGA, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBTSC, ST121R, ST121REU, ST121RGB, ST121UTP, ST121UTP232, ST121UTPEP, ST122LE, ST122LEA, ST122PRO, ST122PROA, ST122UTPA, ST122UTPAEU, ST122UTPAGB, ST122UTPAL, ST122VGA, ST122VGAU, ST122W, ST124PRO, ST124UTPEA, ST124W, ST128PRO, ST222MX, ST222MXA, ST224MX, ST424MX, STDHVHDBT, STUTPEALR, STUTPRXL, STUTPWALLA, SV1631DUSBUK, SV221NANOU, SV231DDUSB, SV231DDVDUA, SV231DVGAU2A, SV231UAF, SV231USB, SV231USBLC, SV431DDVDUA, SV431DVGAU2A, SV431USB, SV565DUTPU, SV565USAGB, SV565UTP, SV565UTPU, SV565UTPUL, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB32HDVGA, USB32VGAEH, USB32VGAEH3, USB32VGAES, USB32VGAPRO, USB32VGAV, USB32VGCAPRO, USB3HDCAP, USB3SDOCKDD, USB3SDOCKHDV, USBC2VGCAPRO, USBVGADOCK2, VGA2HD2, VGA2HDPRO2, VGA2VID, VGAPLATE, VGASPL1VV, VID2VGATV, VID2VGATV2, VID2VGATV3, VS221HD2VGA, VS221VGA2HD, VS410RVGAA, VS721MULTI, WIFI2HDVGA |
