Add a Centronics parallel port to your desktop or laptop PC through USB. The ICUSB1284 6 ft USB to Parallel Printer Adapter - M/M allows USB capable PCs to print to any standard parallel printer, converting a USB port into a Centronics (male) connector for direct connection to a parallel printer.
The USB interface provides a much faster data transfer rate than standard parallel ports, thereby reducing the time spent waiting for a print job or data transfer to be sent.
A portable, space-saving solution, the USB to Parallel Printer Adapter is self-powered and provides Plug and Play installation on Windows based, USB-compliant computers.
Product Description | StarTech.com 6 ft. (1.8 m) USB to Parallel Port Adapter - IEEE-1284 - Male/Male - USB to Centronics Cable (ICUSB1284) - parallel adapter - USB 2.0 - IEEE 1284 | Device Type | Parallel adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Ports | IEEE 1284 | Length | 1.86 m | Data Link Protocol | Parallel | Processor | Prolific PL-2305 | System Requirements | Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows 98SE/2000/ME/XP/Vista/7/8/8.1/10, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0 | Manufacturer Warranty | 1-year warranty |
General | |
Networking | |
Ports | IEEE 1284 |
Connectivity Technology | Wired |
Features | USB powered |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x IEEE 1284 (EPP/ECP) - 36 PIN Centronics - male |
Software / System Requirements | |
OS Required | Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows 98SE/2000/ME/XP/Vista/7/8/8.1/10, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0 |
Dimensions & Weight | |
Length | 1.86 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 80% |
