Connect an IDE hard drive to a Serial ATA power connector. The LP4SATAFM6IN SATA to LP4 Power Cable Adapter features an LP4 female power connector and a male SATA power connector, allowing you to connect an IDE hard drive to a Serial ATA power connector provided by the computer power supply.
Product Description | StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M - Power adapter - SATA power (M) to 4 pin internal power (F) - 5.9 in - black - LP4SATAFM6IN - power adapter - SATA power to 4 PIN internal power - 15 cm | Type | Power adapter | Length | 15 cm | Connector | 15 pin Serial ATA power - male | Connector (Second End) | 4 PIN internal power - female | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: 25S22M2NGFFR, 25SAT22MSAT, HSB225S3R, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATSASBP425 |
General | |
American Wire Gauge (AWG) | 18 |
Length | 15 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
