Extends the length your current USB device cable by 6 inches. The USBEXTAA6IN USB 2.0 Extension Cable features one USB A male connector and one USB A female connector - a reliable and convenient solution for connecting devices to USB ports that are too close to one another (e.g. laptop computers).
Product Description | StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 5.9 in - black - USBEXTAA6IN - USB extension cable - USB to USB - 15 cm | Type | USB extension cable | Length | 15 cm | Connector | 4 pin USB Type A - male | Connector (Second End) | 4 pin USB Type A - female | Compliant Standards | USB / USB 2.0 | Colour | Black | Designed For | P/N: 35FCREADBK3, 35FCREADBU3, MSDREADU2OTG, SU2DUPERA11, USB56KEM3, USB56KEMH2, USBDUP15, USBDUPE115, USBDUPE17, UUSBOTG |
General | |
Length | 15 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compatibility Information | |
