ITEM | QTY | PRICE |
LG 50" UR7800 4K Ultra HD Smart TV
3 | £897.00 |
Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
Product Description | StarTech.com 7 Port USB 3.0 Hub – Up To 5 Gbps – 7 x USB – Universal Multi Port USB Extender for Your Desktop – USB Powered (ST7300USB3B) - hub - 7 ports | Device Type | Hub - 7 ports | Subtype | USB | Ports | 7 x SuperSpeed USB 3.0 | Compliant Standards | USB 1.1, USB 2.0, USB 3.0 | Dimensions (WxDxH) | 20.9 cm x 10.5 cm x 3.5 cm | Weight | 140 g | Colour | Black | System Requirements | Apple MacOS X 10.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits) | Manufacturer Warranty | 2-year warranty | Designed For | P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3LA, UUSBHAUB6IN |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 7 x USB 3.0 Type A , 1 x USB 3.0 Type B |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Colour | Black |
Compliant Standards | Plug and Play, FCC, RoHS |
Software / System Requirements | |
OS Required | Apple MacOS X 10.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits) |
Dimensions & Weight | |
Width | 20.9 cm |
Depth | 10.5 cm |
Height | 3.5 cm |
Weight | 140 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -2 °C |
Max Operating Temperature | 52 °C |
Humidity Range Operating | 5 - 95% |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 56 °C |
Compatibility Information | |
Designed For | P/N: 2SD4FCRU3, BNDTBUSB3142, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A2, PEXUSB314A2V, PEXUSB314A2V2, PEXUSB3S42, SDMSDRWU3AC, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA |
