Add 8 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2328I Industrial 8-Port USB to Serial Hub with DIN Rail Clips converts a single USB port into eight RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this 8 port USB to RS232 Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the USB serial hub ports.
Product Description | StarTech.com 8 Port USB to Serial RS232 Adapter - Wall Mount - Din Rail - COM Port Retention - FTDI USB to DB9 RS232 Hub (ICUSB2328I) - serial adapter - USB 2.0 - RS-232 x 8 | Device Type | Serial adapter | Form Factor | DIN rail mountable | Interface (Bus) Type | USB 2.0 | Ports | RS-232 x 8 | Dimensions (WxDxH) | 9.72 cm x 17.35 cm x 4.32 cm | Weight | 950 g | Data Link Protocol | RS-232 | Data Transfer Rate | 921.6 Kbps | Processor | FTDI FT232RL | Colour | Black | System Requirements | Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Status Indicators | Port status, transmit, receive |
Features | USB powered, wall mountable, DIN rail mountable |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 8 x RS-232 - 9 pin D-Sub (DB-9) - male |
Miscellaneous | |
Cables Included | 1 x USB-A to USB-B cable (external) - 1.83 m |
Mounting Kit | Included |
Compliant Standards | FCC, RoHS |
Colour | Black |
Power | |
Power Device | Power adapter - external |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0 |
Dimensions & Weight | |
Width | 9.72 cm |
Depth | 17.35 cm |
Height | 4.32 cm |
Weight | 950 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 5 - 95% |
