StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsi...
StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector
£11.17
22 in stock
Delivery:
Standard: 1-3 working days
  • Type: Heatsink
  • Stock Status: In Stock
Product codes
Proper cooling systems are arguably the most important part of a fast-running, interruption-free computer. Without adequate cooling, workstations can overheat causing CPU slowdowns and system freezes translating into downtime. Fans like the FAN478 offer great cooling at a great price. Suited for Pentium 4 environments, this super-duty Socket 478 CPU cooler keeps your computer running at optimal temperatures. The closely spaced fins of the aluminum heatsink provide increased heat dissipation, more effective than normal heatsink/fan combos.
Product Description StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector processor cooler
Product Type Processor cooler
Compatibility Socket 423, Socket 478
Heatsink Material Aluminium
Fan Diameter 60 mm
Fan Height 10 mm
Noise Level 29 dB
Power Connector 3-pin plug
Features Ball bearing
Product Material Aluminium
Weight 0.3 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 85x70x50m...
£11.17
