StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA...
StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female
£7.75
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com lifetime warranty
  • Cost-effective solution for connecting a VGA display to a DVI-I video card
  • The 8-inch dongle format reduces the potential of blocking other available ports and removes strain from the DVI connector
  • Stock Status: In Stock
Product codes
Connect your VGA display to a DVI-I source. The DVIVGAMF8IN DVI to VGA cable (8-inch) is used to adapt a DVI male connector to a VGA female connector and enables you to connect a flat panel display to a PC or MAC computer with DVI-I output.
The VGA female connection added by the dongle is situated approximately 8 inches away from the DVI output connection, which lessens strain on and prevents damage to the DVI connector while reducing the potential of blocking other available ports.
The DVI male to VGA female adapter is constructed of high quality materials to ensure dependability.
Product Description StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female Dongle Adapter (DVIVGAMF8IN) - VGA adapter - 20 cm
Type VGA adapter
Technology Shielded
Features Thumbscrews
Length 20 cm
Connector DVI-I - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in DVI t...
£7.75
