Connect a DVI-D device to an HDMI-enabled device using a standard HDMI cable. The HDDVIFM8IN HDMI to DVI-D Video Adapter Cable features one HDMI female connector and one DVI-D male connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
The HDMI to DVI dongle offers 8-inches in cable length, which lessens strain on the connectors and prevents damage to the cable while also reducing the potential of blocking other nearby ports.
Product Description | StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male - HDMI to DVI Dongle Adapter Cable (HDDVIFM8IN) - adapter - HDMI / DVI - 20.32 cm | Cable | Adapter - HDMI / DVI | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 20.32 cm | Colour | Black | Connector | HDMI - female | Connector (Second End) | DVI-D - male | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB |
General | |
Cable Type | Adapter |
Interface Supported | HDMI / DVI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 20.32 cm |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - female |
Connector (Second End) | 24+1 pin digital DVI - male |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
