ITEM | QTY | PRICE |
Synology DiskStation DS620slim 6-Bay...
4 | £1,855.76 |
This Low Profile DB9 Serial Slot Plate Bracket adds a DB9 serial port to the rear panel of small form factor/low profile computer, connecting to the host computer motherboard using an IDC10 connector. Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
Product Description | StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate - Serial panel - DB-9 (M) to 10 pin IDC (F) - 9.1 in - gray - PLATE9MLP - serial panel - DB-9 to 10 PIN IDC - 23 cm | Type | Serial panel | Features | Low profile | Length | 23 cm | Connector | 9 pin D-Sub (DB-9) - male | Connector (Second End) | 10 PIN IDC - female | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 23 cm |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
