Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPG1320C Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC - 20 km (12.4 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Single-Mode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1310nm single-mode SFP module is compatible with Cisco equipment.
Product Description | StarTech.com Cisco GLC-LH-SMD Compatible SFP Module 1000BASE-LH 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver 1GE Gigabit Ethernet SFP LC 20km, 1310nm, DDM, Cisco Firepower, IE2000 - Lifetime Warranty (SFPG1320C) - SFP (mini-GBIC) transceiver module - 1GbE | Device Type | SFP (mini-GBIC) transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 1000Base-LH | Optical Wave Length | 1310 nm | Data Link Protocol | 1GbE | Max Transfer Distance | 20 km | Dimensions (WxDxH) | 0.9 cm x 6.5 cm x 1.4 cm | Weight | 25 g | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, IES101G2SFPW, IES101GP2SFW, MCM1110SFP, PEX1000SFP2 |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI) |
Compliant Standards | IEEE 802.3z |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-LH - LC single-mode |
Compatible Slots | 1 x SFP (mini-GBIC) |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Dimensions & Weight | |
Width | 0.9 cm |
Depth | 6.5 cm |
Height | 1.4 cm |
Weight | 25 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Compatibility Information | |
