Add support for 1000 Mbps RJ45 copper Ethernet connections to networking equipment with spare SFP slots. The SFPC1110 Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module (Mini-GBIC) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
Featuring Digital Diagnostics Monitoring support and 1000 Mbps Auto-negotiation at distances up to 100m (330 feet), this Ethernet SFP module can be installed into any fiber networking devices with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, this copper transceiver is fully hot-pluggable, allowing you to install the module without interrupting network traffic or requiring a device reboot. This SFP module is compatible with the Cisco SFP-GE-T transceiver.
Product Description | StarTech.com Cisco SFP-GE-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 10/100/1000 Mbps, RJ-45 (Copper) 100m, Cisco IE3400, IE3300, IE3200, 1000MbE Mini GBIC Transceiver - Lifetime Warranty (SFPC1110) - SFP (mini-GBIC) transceiver module - 1GbE | Device Type | SFP (mini-GBIC) transceiver module - RJ-45 | Form Factor | Plug-in module | Cabling Type | 1000Base-TX | Data Transfer Rate | 1 Gbps | Data Link Protocol | 1GbE | Max Transfer Distance | 100 m | Dimensions (WxDxH) | 0.9 cm x 5.5 cm x 1.4 cm | Weight | 25 g | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: MCM1110SFP |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Auto-negotiation, auto-uplink (auto MDI/MDI-X) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-TX - RJ-45 |
Compatible Slots | 1 x SFP (mini-GBIC) |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Dimensions & Weight | |
Width | 0.9 cm |
Depth | 5.5 cm |
Height | 1.4 cm |
Weight | 25 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Compatibility Information | |
