The DACSFP10G2M is a Dell EMC DAC-SFP-10G-2M compatible direct-attach copper SFP+ cable that's designed, programmed and tested to work with Dell EMC brand compatible switches and routers and complies with MSA industry standards. This passive Twinax copper cable supports 10 Gigabit Ethernet applications connected through SFP+ (Mini-GBIC) ports. This copper SFP+ cable is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions. Designed for high-speed performance, this low-power, low-latency 10GbE cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com offers a wide variety of direct-attach SFP cables and SFP modules, providing the convenience and reliability you need to ensure dependable network performance.
Product Description | StarTech.com Dell EMC DAC-SFP-10G-2M Compatible 2m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC, SFP Plus - Lifetime Warranty (DACSFP10G2M) - 10GBase direct attach cable - 2 m | Type | 10GBase direct attach cable | Technology | Twinaxial | Features | Passive cable | Length | 2 m | Connector | SFP+ - plug - latched | Connector (Second End) | SFP+ - plug - latched | OEM Manufacturer Equivalent Part Number | Dell EMC DAC-SFP-10G-2M | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | 10GBase direct attach cable |
Impedance | 100 Ohm |
Length | 2 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, REACH, MSA |
Dimensions & Weight (Shipping) | |
Shipping Width | 20 cm |
Shipping Depth | 22 cm |
Shipping Height | 4 cm |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
