StarTech.com Desk Mount Dual Monitor Arm
£209.76
14 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • HEAVY DUTY DUAL MONITOR MOUNT: VESA 75x75/100x100mm compatible desk mount dual monitor arm supports 2 displays up to 32" (16:9) 17.6lb/8kg each; Full motion articulation, aluminum & matte black finish; Mount displays side by side or stacked
  • INCREASE PRODUCTIVITY: With independently mounted arms on a longer pole, this multi monitor arm allows you to optimize space by vertically stacking two 32" (16:9) or ultrawide (32:9) LCD/LED displays; Ideal for smaller workspaces in home/office/cubicle
  • WIDE RANGE OF MOTION: Ergonomic monitor mount increases comfort & productivity with +/-90° tilt, +/-90° swivel, +/-90° rotation (landscape or portrait) & toolless adjustable height; Independent arms for vertically stacked or side by side monitor setup
  • ONE-TOUCH ADJUSTMENT: Full motion double monitor arm with independent toolless 10" adjustable height; Secure each arm along the 19"/480mm pole (limited if displays vertically stacked); Max height of 30"/762mm (displays side by side); Arms reach out 18.4"
  • EASY INSTALLATION: Tighten c-clamp from top with incl. tool or grommet mount to secure to desk (0.4" to 1.9" desk thickness); Articulating monitor arm with detachable VESA plates to easily mount computer monitors; Tools incl. to adjust articulation tension
  • Accessory Type: Monitor/desktop stand, Mounting Solutions
Product codes
chevron icon
chevron icon
This dual monitor arm desk mount enables you to mount two monitors up to 32". The arms are separately attached and stacked to the pole and are easily adjustable for horizontal or vertical monitor positioning. Its solid steel construction makes this monitor arm able to support 17.6lbs (8kg) each with two included mounting options (C-Clamp or Grommet mount) to securely attach your monitors to your desk.
chevron icon
Product Description StarTech.com Desk Mount Dual Monitor Arm, Full Motion Monitor Mount for 2x VESA Displays up to 32" (up to 17lb/8kg), Ergonomic Vertical Stackable Arms, Articulating, Height Adjustable - Pole Mount, C-Clamp/Grommet (ARMDUALPIVOT) mounting kit - full-motion dual arm - for 2 monitors - black
Product Type Mounting kit (full-motion dual arm) - desk-mountable
Mounting Components Pole, 2 monitor arms, base, 2 VESA plates, 2 monitor arm mounts, tool holder
Dimensions (WxDxH) 86 cm x 56.2 cm x 14.5 cm
Tilt -90° to 90°
Rotation -90° to 90°
Swivel -90° to 90°
Adjustments Height, tilt, swivel, rotation
Weight 6.1 kg
Recommended Use 2 monitors
Recommended Display Size 32"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 8 kg
Material Aluminium
Colour Black
Package Content 8 x M4x12 screws, hex key (3mm), grommet plate, 8 x washers, hex key (6mm), 8 x M5x12 screws, 2 x cable management clips
Manufacturer Warranty 5-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£209.76
