Place a display, up to 30" in size, at your desk, using this height-adjustable monitor mount with integrated cable management. The adjustable monitor stand lets you mount a display on your desk, with tilt, pivot and height adjustments for perfect positioning. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The monitor stand holds most common displays with ease, supporting monitors from 12 - 30" up to a maximum weight capacity of 30lbs (14kg). For added flexibility, the included hardware can be used to mount your Apple iMac or Apple Cinema Display.
The desktop monitor stand features a 15in (380mm) tall support post, for a much greater range of height adjustments than typical monitor stands can provide. For viewing longer pages or blocks of code without scrolling, the LCD stand also supports landscape to portrait display rotation.
Adjust your display height, position and viewing angles easily to create an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk by mounting on a support post above the desk surface.
Product Description | StarTech.com Single Monitor Stand - Adjustable - Supports Monitors 12" to 34" - Premium - Single Screen VESA Monitor Mount Stand - Silver (ARMPIVSTND) mounting kit - for LCD display - silver | Product Type | Mounting kit | Mounting Components | Desk stand, feet, wrench, screws, cable clip | Dimensions (WxDxH) | 33 cm x 26 cm x 10.5 cm | Tilt | -15° to 45° | Swivel | 60° | Adjustments | Pan, tilt | Weight | 2.4 kg | Recommended Use | LCD display | Recommended Display Size | 12"-34" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 14 kg | Material | Plastic, steel | Colour | Silver | Manufacturer Warranty | 5-year warranty |
General | |
Width | 33 cm |
Depth | 26 cm |
Height | 10.5 cm |
Weight | 2.4 kg |
Colour | Silver |
AV Furniture | |
Cable Management | Integrated cable management |
Swivel | 60° |
Features | Adjustable height, portrait to landscape movement, swivel adjustment, pivot |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
