ITEM | QTY | PRICE |
C2G 2m SC-SC 9/125 OS1 Duplex Singlem...
3 | £47.97 |
The DP2HDMIADAP DisplayPort to HDMI Adapter provides a DisplayPort male and HDMI female connector, allowing you to keep your existing (HDMI) display while using a DisplayPort video card/source.
Supporting display resolutions of up to 1920 x 1200(computer)/1080p(HDTV), this cost-effective solution maintains the incredible graphical performance offered by DisplayPort, while eliminating the cost of having to upgrade your HDMI capable display to a display with built-in DisplayPort support.
DP2HDMIADAP is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
Applications
Product Description | StarTech.com DisplayPort to HDMI Adapter – 1920x1200 – DP (M) to HDMI (F) Converter for Your Computer Monitor or Display (DP2HDMIADAP) - adapter - DisplayPort / HDMI | Cable | Adapter - DisplayPort / HDMI | Connector | DisplayPort - male | Connector (Second End) | HDMI - female | Manufacturer Warranty | 3-year warranty | Designed For | P/N: DPPNLFM3, DPPNLFM3PW |
