The StarTech.com DP2VGA DisplayPort to VGA adapter lets you connect a VGA computer monitor to a DisplayPort video card or other DisplayPort source, eliminating the expense of upgrading the monitor for compatibility. The DP to VGA adapter uses an integrated chip to provide an active digital to analog conversion.
Product Description | StarTech.com DisplayPort to VGA Adapter - 1920x1200 - Active DP to VGA Video Converter - Plug and Play DP to VGA Connector (DP2VGA) - display adapter - 25 cm | Type | Display adapter | Features | Latched | Length | 25 cm | Connector | DisplayPort - male | Connector (Second End) | HD-15 (VGA) - female | Compliant Standards | FCC | Manufacturer Warranty | 3-year warranty | Designed For | P/N: DK30C2DAGPD, DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SP123DP, SV231DPU, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU |
General | |
Length | 25 cm |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
Compatibility Information | |
