StarTech.com DP to HDMI or VGA Converter
£22.20
Delivery:
Standard: 1-3 working days
Key features
  • 2-in-1 adapter lets you connect your DP computer to any HDMI or VGA display with a single adapter
  • Maximize portability with a compact, lightweight adapter that you can easily carry in your laptop bag
  • Supports video resolutions up to 1920x1200 or 1080p
Product codes
chevron icon
chevron icon
Connect your DisplayPort equipped computer system to an HDMI or VGA display. This DisplayPort to HDMI + VGA travel adapter lets you connect your DP enabled Ultrabook or laptop computer to any VGA or HDMI display.
Why keep several adapters when you only need one? With this single DisplayPort tor VGA and HDMI adapter you can rest assured that your computer can interface with any modern boardroom or classroom display. It's the ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p, you can convert your DisplayPort video source to HDMI or VGA without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. This convenient construction ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter.
With this adapter you can walk into virtually any boardroom ready to present, making a great first impression and saving you the embarrassment of having to rummage through your bag looking for the right connector. Plus, the 2-in-1 converter installs easily with no software or drivers required.
chevron icon
Product Description StarTech.com 2 in 1 Displayport Adapter - DisplayPort to HDMI or VGA - DisplayPort Adapter - 1920x1200 - Travel Adapter (DP2HDVGA) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Dimensions (WxDxH) 5.8 cm x 19 cm x 1.3 cm
Enclosure Colour Black
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£22.20
