We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Add copied or ghosted EDID (Extended Display Identification Data) to your HDMI signal to ensure compatibility with your display or projector. This EDID emulator resolves video communication problems that can occur between your HDMI video source and display. The emulator can copy or synthesize the Extended Display Identification Data (EDID) from your HDMI display and relay it to your video source, to fix problems that may result from using third-party equipment such as video extenders, video switches or KVMs in your video setup.
EDID contains important information that your television or projector needs, to deliver its best picture quality. Because most video extenders or switches block EDID communication between your video source and display, EDID is often lost in transmission, limiting your video source's ability to output your display's native resolution. Using the EDID emulator, you can ensure your HDMI source and display are perfectly in sync, for crystal-clear picture quality.
To ensure that any EDID communication issue can be solved, the EDID emulator supports both EDID copying and EDID ghosting.
EDID copying saves the EDID settings from your display and communicates those exact settings to your source, which is perfect for EDID issues that are caused by a third-party disruption, such as a video switch or extender.
EDID ghosting lets you emulate generic EDID settings, to deliver common data to your source or display. This is the perfect solution for EDID issues that often occur when you're working with devices that don't output EDID, such as older legacy equipment or some analog to digital video adapters.
EDID communications contain a lot of important settings, such as maximum image size, color characteristics, factory preset timings, frequency range limits and more. With all of these specific details, it's easy to be confused or crossed up by the data. This emulator eliminates the hassle and confusion that comes with EDID, giving you a rotary dial that you can use to configure all of your settings in one simple step.
Product Description | StarTech.com EDID Emulator for HDMI Displays - Copy Extended Display Identification Data - 1080p (VSEDIDHD) - EDID reader / writer - HDMI | Device Type | EDID reader / writer | Interface Type | HDMI | Dimensions (WxDxH) | 5.2 cm x 8 cm x 2.2 cm | Weight | 123 g | Colour | Black | Included Input Adapter Accessories | 4 x foot pads, screwdriver, USB power cable | Digital Video Capture Resolution | 1280 x 720, 1600 x 1200, 1024 x 768, 1280 x 1024, 1920 x 1080, 1440 x 900, 1680 x 1050, 1600 x 900, 1366 x 768 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 5.2 cm |
Depth | 8 cm |
Height | 2.2 cm |
Weight | 123 g |
Colour | Black |
Video | |
Expansion / Connectivity | |
Interfaces | 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - HDMI output - 19 pin HDMI Type A |
Connections | 1 x display / video - HDMI input - 19 pin HDMI Type A , 1 x display / video - HDMI output - 19 pin HDMI Type A |
Miscellaneous | |
Included Accessories | 4 x foot pads, screwdriver, USB power cable |
Device Features | USB powered |
Compliant Standards | FCC, RoHS, WEEE |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 80% |
