Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multimode LC fiber. The ET91000LC2 1000 Mbps Gigabit Multimode Fiber Media Converter (LC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, this GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet-to-fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U), as well as a replaceable SFP slot.
Product Description | StarTech.com Multimode (MM) LC Fiber Media Converter for 1Gbe Network - 550m Range - Gigabit Ethernet - 850nm - with SFP Transceiver (ET91000LC2) - fibre media converter - 1GbE | Device Type | Fibre media converter - RJ-45 / LC multi-mode | Form Factor | External | Localisation | North America, United Kingdom, Europe | Cabling Type | 1000Base-LX, 1000Base-SX, 1000Base-T | Data Transfer Rate | 1 Gbps | Optical Wave Length | 850 nm | Data Link Protocol | 1GbE | Max Transfer Distance | 550 m | Power | AC 120/230 V | Dimensions (WxDxH) | 9.5 cm x 16 cm x 2 cm | Weight | 0.62 kg | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA |
General | |
Device Type | Fibre media converter |
Colour | Black |
Networking | |
Connectivity Technology | Wired |
Features | Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, rugged |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC multi-mode female x 2 |
Miscellaneous | |
MTBF | 65,000 hours |
Compliant Standards | Plug and Play, FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Dimensions & Weight | |
Width | 9.5 cm |
Depth | 16 cm |
Height | 2 cm |
Weight | 0.62 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
