StarTech.com Hard Disk Drive Duplicator Dock
£120.13
16 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • DUPLICATE AND DOCK SATA DRIVES: This dual bay hard drive duplicator features standalone drive cloning of 2.5/3.5" SATA drives with no computer required. This dock can also be used as a USB to SATA adapter for quick access to your SATA drives over USB
  • DRIVE COMPATIBILITY: Works with 2.5/3.5" SATA HDDS and SSDs of any capacity | 4Kn Compatible | OS Independent | Backwards compatible w/ SATA I/II |Includes 3ft USB-C/A cables and Universal Power Adapter | IDE adapter (SAT2IDEADP) sold separately
  • DUPLICATION MODE: Standalone sector-by-sector duplication works with any file format and copies the entire drive, including empty sectors, at speeds up to 28 GB/min. Target disk must be equal/larger than the source disk.
  • SPECS: 2-Bay Duplicator Dock with TRIM | SATA III (6 Gbps) | USB 3.2 Gen 2 (10 Gbps) Host Connection (optional)| Tool-less/Tray-less Design | Top-Loading (Toaster style) w/ Drive Doors & Eject Buttons | Power & Status Multi-function LEDs
  • THE IT PRO'S CHOICE: Designed and built for IT Professionals, this hard drive duplicator dock is backed for 2 years, including free lifetime 24/5 multilingual technical assistance.
  • Type: Hard drive Duplicator
  • HD Size: 2.5 / 3.5 shared
  • Power Supply: Power adapter
Product codes
chevron icon
chevron icon
Duplicate or dock a SATA SSD/HDD with fast performance - works with both USB-C and USB-A enabled devices. Duplicate drives quickly, at rates of up to 28GB per minute for SSDs, without having to connect to your computer. This duplicator dock offers standalone drive cloning that makes it easy to back up your data and make exact images of your drives. You can also connect the dock to your computer through USB 3.1 (10Gbps), to dock and swap your drives as part of a scalable storage solution.
Duplicating a hard drive or solid-state drive is an effective way to migrate your operating system and data from one drive to another, or create an exact copy for safeguarding your important data. This drive duplicator lets you create a sector-by-sector clone of your drive, including partitions and boot sector information, to ensure data integrity and consistency for sensitive operations such as data recovery.
The duplicator dock saves you valuable time with SSD duplication speeds of up to 28GB per minute. You can duplicate a 2.5" or 3.5" SATA SSD or HDD easily, without having to connect the duplicator to a host computer.
The duplicator dock also provides an external storage solution, letting you dock your drives through USB 3.1 Gen 2 with UASP support, enabling fast data transfer rates of up to 10Gbps. Each drive slot individually supports a high-capacity hard drive or solid-state drive, tested up to 6 TB.
The duplicator dock comes with two USB cables for flexible use with the latest laptops and tablets equipped with a USB-C port, as well as legacy devices. It includes both USB-C to B and USB-A to B cables. The duplicator dock is also compatible with a Thunderbolt 3 USB-C port.
The dock features a top-loading, toaster-style design that makes it easy to insert your drives. It also features drive doors to help stabilize drives that are inserted into the slot and prevent foreign objects from getting into the drive slots.
Both tool-less and tray-less, the duplicator dock helps to ensure quick and hassle-free drive insertions. LED indicators let you know, at a glance, the current state of the duplication process, including the specific duplication mode, the HDD status and clone progress. The HDD ejection button enables fast and simple drive removal.
For added compatibility with different drive types in duplication and docking applications, the SDOCK2U33RE supports the use of various drive adapters. The below list of StarTech.com adapters have been specifically tested, to ensure compatibility with this drive duplicator: SATA to 2.5in or 3.5in IDE Drive Adapter - SAT2IDEADP; 2.5in SATA to Mini SATA SSD Adapter - SAT2MSAT25; M.2 SSD to 2.5in SATA Adapter - SAT32M225.
chevron icon
Product Description StarTech.com Standalone Hard Drive Duplicator, Dual Bay HDDSSD ClonerCopier, USB 3.1 (10 Gbps) to SATA III (6Gbps) HDDSSD Docking Station, Hard Disk Duplicator Dock - Hard Drive Cloner - hard drive duplicator
Device Type Hard drive duplicator
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-300
Duplication Speed 28 GBpm
Storage Controller SATA (SATA 3Gb/s)
Hard Drive No HDD
Dimensions (WxDxH) 13.2 cm x 14.2 cm x 7 cm
Weight 508 g
Designed For P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£120.13
