Protect your laptop against theft with this convenient combination lock. This laptop lock gives you an easy and effective way to secure your laptop to a sturdy object and keep it safe from theft. With this 4-digit combination lock, you can be confident your laptop and valuable data are well protected.
You can ensure that your laptop, monitor, docking station or other electronic device will be anchored safely to your workspace in just a few simple steps with this keyless 4-digit combination lock. It effortlessly latches directly into any laptop or other device equipped with a built-in security-lock slot, providing dependable theft prevention in a wide range of retail, commercial, and institutional environments.
Featuring a vinyl-coated steel cable (6 mm diameter), this laptop lock is designed for effective theft prevention.
Product Description | StarTech.com Laptop Combination Lock - Security Lock - 6 Ft Vinyl-Coated Steel Cable (LTLOCK) - security cable lock | Product Type | Security cable lock | Colour | Black & silver | Product Material | Vinyl, steel | Dimensions (WxDxH) | 0.6 cm 0.6 cm | Length | 1.8 m | Weight | 182 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CH2DPPDU, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, USB3DDOCKFT, USB3DOCKH2DP, USB3VDOCK4DP, USB3VDOCKD |
General | |
Width | 0.6 cm |
Height | 0.6 cm |
Length | 1.8 m |
Weight | 182 g |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 2 years |
Compatibility Information | |
