This LP4 to SATA Power Adapter Cable features an LP4 female connector as well as an SP4 female power connector and a SATA power connector, allowing you to connect an IDE hard drive as well as a floppy disk drive to a Serial ATA power connector provided by the computer power supply. This high quality LP4/SATA power adapter cable is expertly designed for durability.
Product Description | StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power (LP4SATAFMD) - power adapter | Type | Power adapter | Connectors | 15 pin Serial ATA power - male | Connectors (Second End) | 4 PIN internal power - female , 4 PIN mini-power connector - female | Colour | Black | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: DRW110SATBK, PEX2M2, PEXM2SAT3422, S251BU31REM, S25SLOTR, SATSASBP425 |
General | |
Colour | Black |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
