Turn your M.2 NGFF SATA drive into an ultra-fast, ultra-portable storage solution for USB-C enabled devices. This compact M.2 SSD enclosure lets you add highly portable data storage to any laptop or computer with a USB-C port - such as MacBook, Chromebook Pixel, Dell XPS laptops, and many others. It turns your SATA M.2 drive into a high-speed storage solution over a USB 3.1 Gen 2 connection, at up to 10Gbps throughput.
This slim, pocket-sized M.2 NGFF SSD enclosure has been specially designed for mobility, with a small form factor design that fits easily into your laptop bag. Its lightweight yet durable aluminum housing helps to ensure your drive won't be damaged while you're on the move.
Ventilation holes help to dissipate heat and help ensure an optimum operating temperature.
Leverage the speed of your M.2 NGFF SATA drive with this external enclosure. It delivers USB 3.1 Gen 2 data transfer speeds up to 10Gbps as well as UASP support, so you can achieve higher transfer speeds when you connect it to a UASP-enabled host computer.
The enclosure works with tablets, laptops and desktop computers and is compatible with hosts equipped with Thunderbolt 3 USB-C ports.
The enclosure is compatible with all of the common M.2 SSDs, and enables you to mount multiple drive lengths, including: 30mm (2230), 42mm (2242), 60mm (2260), and 80mm (2280).
Product Description | StarTech.com M.2 SSD Enclosure for M.2 SATA SSDs - USB 3.1 (10Gbps) with USB-C Cable - External Enclosure for USB-C Host - Aluminum (SM21BMU31C3) - storage enclosure - SATA 6Gb/s - USB 3.1 (Gen 2) | Device Type | Storage enclosure - external | Bus Type | USB 3.1 (Gen 2) | Colour | Black, silver | Expansion Bays | 1 x internal - M.2 | Hard Drive Form Factor Compatibility | M.2 | Interface | SATA 6Gb/s | Data Transfer Rate | 6 Gbit/s | Supported Devices | Solid state drive | Max Storage Devices Qty | 1 | Product Material | Aluminium | Dimensions (WxDxH) | 8 cm x 1.2 cm x 9.85 cm | Weight | 55 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: TBLT3MM1MA, TBLT3MM2M, TBLT3MM2MA |
General | |
Host Bus | USB 3.1 (Gen 2) |
Storage Controller | |
Processor | ASMedia ASM1153 |
Expansion / Connectivity | |
Interfaces | 1 x SATA 6Gb/s - SATA combo |
Connections | 1 x USB 3.1 (Gen 2) - 24 pin USB-C |
Miscellaneous | |
Included Accessories | Screwdriver, screws |
Cables Included | 1 x USB cable - external |
Features | USB powered, UASP transfer protocol, ventilation holes |
Compliant Standards | FCC, RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 8 cm |
Depth | 1.2 cm |
Height | 9.85 cm |
Weight | 55 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
