Add a Gigabit RJ45 port through a Mini PCI Express slot. The ST1000SMPEX Mini PCI Express Gigabit Network Adapter Card adds 1000Mbps network connectivity to a Mini PCI Express (PCI Express Mini Card, Mini PCIe) enabled computer system, such as Mini-ITX motherboards. Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this Mini PCI Express Gigabit Adapter is ready to handle a wide variety of scenarios. Perfect for small form factor or embedded systems that originally lack Gigabit networking capability, or for adding a network connection without taking up a full-sized PCI Express slots, this high quality Mini PCIe Network Adapter includes a low profile/half-height bracket for additional installation options.
Product Description | StarTech.com Mini PCIe Card - 10/100/1000Mbps RJ45 Port - IEEE 802.3 - Jumbo Frame - Network Card (ST1000SMPEX) - network adapter - PCIe Mini Card - Gigabit Ethernet | Device Type | Network adapter | Form Factor | Plug-in card | Interface (Bus) Type | PCI Express Mini Card | Ports | Gigabit Ethernet | Dimensions (WxDxH) | 4 mm x 5.1 cm x 3 cm | Weight | 150 g | Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE | Data Transfer Rate | 1 Gbps | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Status Indicators | Link/activity |
Features | Full duplex capability, remote Wake Up, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), Jumbo Frames support |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Compatible Slots | 1 x PCI Express Mini Card - full-length |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.x - 10.5.x, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 |
Dimensions & Weight | |
Width | 4 mm |
Depth | 5.1 cm |
Height | 3 cm |
Weight | 150 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 5 - 95% |
